Do i need pd150 head bolts?
Perfect thank you very much. I have a Haynes manual so that will make more sense when it comes to the sequence.
JRJG
Sequence is not required when changing one bolt at a time,start where you want :)
Sequence is only for when the head is being removed,so the pressure is released equally over the head so it doesn't risk distortion
Ah okay - that makes things easier, start at a corner and go clockwise then! Thank you very much for clarifying.
JRJG
  • 2 years later...
I’ve got a polo pd130 but just got the pd150 turbo, I already have a fmic and hardpipes, will I need pd150 head bolts as well or am I able to keep the ones already on?
You should change the bolts to prevent problems with the increased boost from the new turbo. Why wouldn't you, it's an easy job.
I never had them with a hybrid pd150 but as stated it is a good idea to change them for the cost and time its definitely worth it.
Do one at a time.
OK, I'm not re-reading the entire thread, but would you be best to do them in the "tightening order" for a head gasket replacement?
