1.4 TSI Twincharge?
May soon be in market for newer Octavia 2 or possibly early Octavia 3.
Thinking about 1.4 TSI but want to avoid twincharge.
Which ones  have twincharge?
Can you tell from codes on sticker on boot floor?
Octavia MK III - All the 1.2 & 1.4 tsi engines are the later EA211 engine (new totally different engine turbo only, belt cam)
Very good engines
Octavia MK II - The  1.2 & 1.4 tsi engines are the earlier EA111 engine (turbo only, chain cam) but none have the twin charger (turbo + supercharger)
Later versions are good but some earlier versions can have cam chain issues (regular servicing important)
Fabia MK II VRS - The more powerful 1.4tsi engine is the twin charger and is the engine that has had the most issues (oil consumption, pistons, cam chain) usually involving a replacement engine although recent versions sorted
http://www.briskoda.net/forums/topic/358101-vrs-mk-ii-14-litre-twincharger-oil-consumption-issues/
Edited by bigjohn
Very good engines
That sounds encouraging then, especially for the Octavia 3. Unfortunately a 3 would be a bit of a stretch so a late model Octavia 2 is more likely. Any Idea of build dates or chassis numbers that would indicate the better later versions?
buy a Mk2 1.8tsi manual
