Some clarification plz!
is it possible that your DPF is so clogged so that you can't force regenerate.
It is all Russian Roulette - you can try whatever you want but if ECU doesn't like values...you're screwed.
You can take it off, get all large particles out. Burn it out with petrol and fire...it may work, it may not.
Mesh in DPF is fine and once it is clogged, you have to buy new one.
TDi cars are designed for long distances at constant speeds. It takes your engine to warm up at 0 deg C around 20-30km. Until then, your engine spills unburnt fuel into DPF and clogs it.
If you check out this forum, there is many idiots who drive short distances and then cry about dead DPF. Turbo cars are not for daily drive ;-)
Edited by sniper29a
  • Replies 79
  • Views 7k
  • Damn - was hoping it was that, change the bloody thing and stop thinking bout it!!+ Thanks mike
  • ECU maps are related to engine load/pedal   so called Driver wish map...unless you have some 1.4-1.6TDi car...you rarely get full boost.   1400kg Octavia 2 with 103kW requires about 200Nm for high
  • read the post...most likely faulty MAF ;-)   Original turbo cost 14k CZK, which is around 500GBP ;-)  Original turbo with sealing set cost 1000GBP (no idea what sort of o-rings, sealing you get) so
From where should i buy new one?
no idea, I live in Austria and buy in Czech Republic where I was born and people buy directly from VW manufacturers.
12k CZK/440EUR cost an original DPF
I've got an passat cc 2010 dsg 170 bhp, are quite expensive in uk.
Hello again, can some one tell me how an diverted valve sound like when is foulty? Thanks
