Will Fabia black headlights fit
I have been offered a set of fabia Carlo headlamps that are darkened And wondered if they would fit my 15 plate roomster
I know the cars are identical front endwise
The Monte in question is a 13/14 plate car
What's making me question it is I read somewhere the darkened lamps only have one bulb and a shutter as opposed to seperate dipped and main beam bulb buy wasn't sure if that only applied to prefacelift 2010 cars
Thank you
My 2010 Roomster has separate light units for full and dip. Each has only 1 bulb.
Thank you I'll double check on etka on the part numbers aswell
Yes they will physically fit, but the loon is different so you'd have to make alterations to that. Change the plugs etc.
It has been done in the past.
How strange one would have thought they would be a direct fit
Can I ask what's different about the lamps as apart from the lens colour it thought they were identical
Which headlights have you got in now? Silver reflector lenses or the projectors with reflector high beam?
The blackpack lights do use 1 H7 bulb. Theres a shutter which controls low and high beam. The reflector with the sidelight in does nothing.
Edited by fabiamk2SE
Ah I see
Yes I currently have the de projector modules (fishbowls)
Thanks for clearing that up
