1998 Felicia gear linkage
Does anyone know if there is a gear linkage repair kit available for a 1998 Felicia?
Mine has developed excessive wear in the rose joint at the top of the small lever arm.
I fear a complete new linkage may be the only option with these assemblies.
Thanks.
hi, i am also a felicia owner but fairly new to skoda and also to this forum i would say at a guess they should be parts available , best bet might be to ring a skoda dealer to ask what they have in stock , would you let us know how you go on as i and other felicia owners might encounter the same problem at a later date , good luck .
ETKA shows all the gear linkage parts as being available individually - so a dealer will be able to get the parts you need.
The bushes are quite a common fault.
Many thanks.
I shall investigate with dealer soon and post reply when sorted.
What is ETKA?
Is this a downloadable parts catalogue. If so I would be grateful for a link.
It is a parts catalogue, not usually downloadable but there are copies floating about the t'interweb.
