Skoda Fabia timing out
Hi my skoda Fabia vrs 1.9tdi has possibly jumped the timing. Not 100%sure though but anyway before I take the head etc off to check for damage I've been told to set the timing. How do I check if the timing is out or set it back to place? What all do I need etc. Cheers
The simplest way to check is with VAG COM. The torsion value should be +/- 3.
If you are sure the timing belt has jumped one tooth then get it checked out ASAP, these belts don't jump a tooth without good reason and something very serious must be wrong to have caused it.
Crank locking tool in and cam locking pin in. Doesn't need to be stripped right down to do it. Just the bottom pulley off and top cambelt cover.
