Handbrake not releasing new caliper causing warm wheel
Hi
Recently I have changed all the brakes, disks, caliper (only both rear one) of my Octavia 1.9 TDI. But now the handbrakes behaves strangely. Sometimes the handbrakes lever becomes hard & sometime it is soft to pull. This cause intermittent brakes. The brakes works good all the time but when I release the lever it sometime does not release the calliper fully which cause my rear right wheel to get warm if I drive :(.
Can you help me troubleshooting the failure in my car...
mvh
KTH
If you have done the calliper's, discs etc and you still have a problem with the brakes grabbing intermittently, then I would be looking at changing the handbrake cables as well. Sounds to me like one is grabbing the internal sleeve and binding.
Also check the alloy guide tubes for the cables as I had a simikar problem and the o/s tube had split.
Not expensive but a bit of a pain to change.
Hi
Could you explain guide tubes for the cables ? where can I find it ?
Sorry only just popped back on.
The guides that the cable runs through to the lever.
Hi
I think you are spot on.
After letting the problem live with me for couple of weeks in order to diagnose. I think I have something similar to what you explain.
As I said the problem is intermittent. I pulled the handbrak yesterday to park my car and this morning the wheel was again jammed and handbrake was soft. Than I press the paddle brake and I heard the sound "DIK" from the handbrake and vilolla the wheel get release immediately and handbrake gets normal again. Do you see something similar, clue ?
  • 4 weeks later...
Does anybody has any answer to the problem ?
Hi
have you checked the caliper guide pins weren't damaged when you had the brakes worked on ? Or perhaps the handbrake cable is not fully installed and sometimes gets caught on something.
Sorry havnt been on much.
The easiest way to check if the cables are sticking is to disconnect them at both ends and see if the move freely in the guides.
Shouldnt take long.
