Power steering fluid change
Hi All
Contemplating changing the PAS fluid on the VRS.
What's the correct / best fluid to replace with?
How much do I need?
What's the best method to replace it?
Dave
It's not April already surely?
The Scots are now in a breakaway pro EU independence day mode. They can have hydraulic power steering while us Scots exiles have to make do with the all electric power steering
Next up, what coolant goes in my 1960 VW Beetle?
  • Sponsor
"For the first time in Skoda Octavia, an electro/mechanical steering with double pinion is used and replaces the hydraulic steering assistance of the previous model. The steering support results from a separate transmission, which is effective on the steering rack and is driven by an electric motor."
Or a clutch cable for a Porsche 944
Off to buy and skirting board ladder and some tartan paint
Is there any maintenance on the steering setup?
Good stuff. Every day is a school day. That's another job well done then.
Hi All
How much do I need?
Dave
Good luck with that.  :notme:
About the only thing you can do is make sure the electrical connections aren't corroded.
