Tyres - 195/45/16/or 205/455/16 on VRS Alloys
Just a quick one,
i am buying some tyres and have narrowed it down to 2 brands.
195/45/16 84W Yokohama S Drive AS01
or
195/45/16 R16 87W Toyo Proxes T1-R
Also i have Mk1 VRS 16in alloy wheels.
Should i go for the 195's or the 205's ?
I know that one is 10mm narrower.....
The other difference is the price between them approx £40 or £10 per tyre.
What is the difference?
Does anyone have any words of wisdom?
thanks
Pedro
Apologies,
should have added that my Fabia is a 1.4 16V 2005 Estate
thanks in advance
Pedro
Use the narrower tyres, will make it a bit snappier and safer in the wet since the 1.4 is a lot lighter than the PD.
Use one of the free on line tyre calculaters,enter your original wheel/tyre size then you can work out which one will give you nearest to your original rolling radius to keep your speedo correct.
If your going to fit 195 tyres i think that they fit 195/50/16 not 195/45/16
Negative, 195/50/15 here on a 1.4 16v and a 2.0 MPI, 185/60/14 is standard on the 1.4 16v.
195/50/16 will be MUCH too big for the 1.4, be like driving in sixth gear all the time.
