Skoda yeti
When driving down a smooth road there is a rumbling through the pedals it's annoying been in to the dealers twice.they said it normal wasn't like than we new it's done 8000 miles and nearly a year old. Has any else had this problem.
Hi Andy  :hi:
Welcome to Briskoda......
This question would solicit more responses if it was in the Yeti Forum where questions such as this will get lots of viewing. This "Technical Guides section is more for projects and technical information. Perhaps one of our excellent moderators will move it for you?........Tony
PS: Not had anything like what you describe in six years of Yeti ownership
Topic moved. :thumbup:
Assuming its not something obvious like a damaged tyre, or wheel that's lost a balance weight then might be a loose mounting bolt.
A mechanic would need to road test it.
Had a previous car that vibrated when cornering, turned out it had a faulty CV joint on drive shaft to one of the front wheels.
As said, not a known issue specific to Yeti's so could be wheel balance or tyre related.
Is it a diesel manual and is the rumbling mostly felt on the clutch pedal?
