Fan On Start Up
Is it normal for the radiator fan to operate just after starting up after the cars been standing for a few hours?
Haven't seen any variation in the normal temp readings.
if air con is on the fans will be on.
Thanks K
How about if the climate control is set to ECON?
so if i turn on the aircon i can test the fans? just wondering because i had a water temp issue this am, see post below, and want to eliminate fans or sensors?
Originally posted by SkodiRS in this post
Thanks K
Unlikely, Adrian, as the compressor will not be on. No need to force air through the condenser if the system isn't running.
Howard,
that's what I thought although not to such details as you described.;)
When I start my car in the morning, if I rev it, the radiator fan comes on briefly. The climate control is set to ECON.
Like I said not variation in the way the temp gauge works......I suppose I should go to the garage again?:rolleyes:
Cheers.
Adrian.
Hmm. I've noticed a couple of strange things with the climate system. If, on a hot summer's day, you get in the car and set the climate to AUTO, there's a rush of air for about 10 seconds, then a noticeable dip in airflow, followed by an even faster rush of air.
What I think is happening is that the climate is, in effect, booting up, and it goes through a series of self-checks before it starts full operation.
If we apply that principle to your scenario, then I wonder if its part of the system self-test to spin up the cooling fans to determine if they are working (possibly a voltage drop or current check)? If they don't appear to be working then I guess it might disable AUTO mode (or at least not allow the compressor to be started).
As long as they go off again shortly afterwards I wouldn't worry too much. :)
Had temp gauge issue a few weeks back - I was mislead by the fans comming on from cold but I tend to have on auto all the time - and garage confirmed as big k has that with air con on the fans run.
Not sure what the garage did but the did sort the temp gauge not reaching normal 90deg after a long run - did not ask for warrenty sig or list on service sheet but alls fine now even in this cold weather.
John
