Iphone 6S Plus and Bluetooth
Hi,
I changed my phone to the one above.  When I got it I was able to connect it to the BT in the car.
I tried to make a call yesterday and while it connected ok, the voice on the other end was breaking up.  When I got home I was able to make a call on my mobile as normal.  So it leads me to an issue in the car.
Why would it work initially then stop?
Does anyone have any one have any advice on this?
If you post which BT module you have fitted people may be able to advise further.
I have a 6 Plus and it connects fine to my BT module.
Edited by KBPhoto
I have a 6S which works fine..... Are you sure it wasn't a network or coverage issue with that call..... You have tried it since with the same poor results haven't you??? And to various numbers etc....
Panic over.  Tried again on Friday and all is well.  Took a call this morning as well and worked fine.  Must just have been a glitch.
Bluetooth is a shaky system anyway, has a mind of its own.
Mine works just fine with my 6 Plus
