Four plus parts
Has anyone used brake pads and discs from the four plus parts range
Any views on them
Also I have a 2012 skoda octavia greenline estate. When I look in Eurocarparts for brakes it lists 2 X disc sizes anyone know if it will have the larger or smaller discs or is it a case of getting tape measure out
Any views on them
There will be a brake pr code on the first page of the service book , the euros web site will show the pr codes for the discs in the fitment section .
I just ordered front pads from number1forskoda on eBay. Genuine pads for a Vrs, £57 down from £74. Had to replace brand new mintex pads that were manafactured wrong on one pad.
The pr codes showing in the front of the service book don't patch any of the pr codes on the Eurocarparts list
Am I missing something
Just phone a Skoda dealer ask for prices and part nos., (both original and 4plus) they would probably tell you the size from the description, too.
Personally as Skoda state openly that 4plus parts are not made to the same standard as original parts, ie they are cheap aftermarket parts, I'd prefer to use euro car parts and select one of the OE brands (eg ATE) probably cheaper too. Might be cheaper still from carparts4less (same company as eurocarparts), don't forget to wait and catch the 30% discount codes.
And then there is Briskoda parts, you can pm them and they will get back to you with a comprehensive quote for original parts.
http://www.briskoda.net/forums/topic/370343-briskoda-parts-genuine-skoda-dealer-parts-other-marques/
Edited by xman
these are my pr codes
E0W = Special edition
1D0 = Without trailer hitch
5SJ = Left exterior mirror: convex
5RV = Right exterior mirror: aspherical
1KD = Disc brakes, rear
6FB = Body-colored exterior mirror housings
1AT = Electronic stabilization program (ESP)
3FA = Without roof insert (standard roof)
1NS = Covers for wheel hubs/wheel bolts
1NL = Covers for alloy wheels
HW7 = Tires 195/65 R15 91H (Blue Motion)
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
4R5 = Power windows with comfort operation andcircuit breaker, mechanical window regulators rear
3KD = Rear seat bench/backrest, split folding
3QT = 3-point seat belts with tensioner and height adjustment, front
4X1 = Side air bag front
4A0 = Without seat heater
8L5 = Roof antenna and "diversity" window antenna
J2D = Battery 380 A (68 Ah)
QI6 = Service indicator 30,000 km or 2 year ( variable )
8GU = Alternator 140 A
6Y0 = Without cruise control warning system
KH6 = Electronically controlled air conditioning system
8RE = 4 speakers (passive)
7Q0 = Without navigation device
8AG = Radio with CD/MP3
8QL = Key for locking system with remote control
8X0 = Without headlight washer system
4KS = Side and rear windows
B09 = Type approval Great Britain and NorthernIreland
7MG = Emission standard EU5
QN0 = Without drawers under front seats
3L2 = Manual height adjustment for right frontseat
9P1 = Seat belt reminder, electric contact in buckle
7X0 = Without park distance control
3GA = Without cargo area
7AH = Electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn
G02 = Front shock absorption
L07 = Suspension range 07 installation control only, no requirement forecast
7P0 = Without lumbar support in seat backrests
F0A = No special purpose vehicle, standard equipment
3S2 = Black roof rails
2UA = Standard design
does anyone still use copper slip when fitting new pads or do they just rely on the materials on the back of the pads plus any shims that are supplied
have translated all my pr codes but non mention the front brakes
Edited by mike4scuba
front brakes PR code seem to be missing all 3 service books I have. Used a tape measure and matched to drawings in my case.
Copperslip is likely to lead to electroltytic corrosion and is a dust magnet. The correct stuff to use is Cera tec non metallic brake grease.
http://www.eurocarparts.com/ecp/c/Skoda_Octavia_1.8_2011/p/car-accessories/car-maintenance-accessories/maintenance-fluids-and-greases/grease/?526770250&0&cc5_150
Its a lot less messy than copperslip and it stays where you put it.
