More issues with my Octavia :-(
You never are with these cars. I need to sort a few knocks. It hunts a little on idle. The sia is shot. I love my octy its never boring. My fabia vrs never really needed work. Still a fun car
Mine does that, its getting worse but I suspect its a leaky pipe.
need to get under the car and have a look,
  • Replies 52
  • Views 4k
  • Usually some kittenhole has jacked up the car on the rear beam and bent it to kitten.
  • Probably best to get it onto a four wheel laser alignment rig, so they can check the complete set up.
  • In joke, based on having once configured the swear filters to replace the word being censored with "kitten".
the hunting on idle is going to be 1 of a few things.
 - First on the list is check all vacuum hoses, if any look old or worn then replace them. Warning, there are a lot on these engines.
 - Next is coil packs, this engine actually had a recall for them but there are kits to upgrade them to 2.0T ones.
 - Coil pack loom is another thing to check as they sit in a hot part of the engine so dry out and crack over time. PIG of a job to do.
On the first cylinder on the left, the plastic sheet on one of these cables is cracked. Ive had a ecu scan done and its not given any error codes.
Very odd issue.
