HELP ! Twindoor wiring .... or NOT
Good Afternoon
I have a 2010 Superb twindoor elegance dsg
I have an intermittent issue with the boot mechanism. it intermittently works.
I have replaced the wiring loom 3 times and the boot switch once does anyone else have any other ideas?
How far back in the headlining is the connection to the boot?  Am I missing something?
Please help this is just so annoying
T
There isn't a connection for the boot loom, it's part of the main harness.
Cheers anything else that may cause the boot to not be pulled close
There are a multitude of sensors and switches. Need to have a look in the data blocks using VCDS to see if anything is out of spec.
00380 special vehicle control module J608 no signal no communication
So the software can make the latch rise from an attached computer but not lower. Would there be a software update from Skoda that would effect the boot control module / ecu special control module
