Please help Lambda idle self adaptation %20 !
Hi, my car is a 1.6 8v 102hp bora BFQ motor with LPG , I have problem for lean condition , but I can not resolve !!
I record a video please watch it
https://www.youtube.com/watch?v=h4Q7...ature=youtu.be
What I did ? :
1- Manifolt gasket changed !
2- Bank1 sensor 1 lambda sensor changed > > It's failed ( But I suspect new one ! I get a bosch , original one is NTK ) maybe at idle , It doesn't read regularly ? Is it possible ?
3- I did a smoke test there is no leak ?
4- MAF sensor ? please watch the video
5-Does Injector leaking cause lean condition ? I didn't clean it ? maybe I must clean ?
I'm watinig for your suggestions , Thank you
Could be a failing coolant temp sensor causing the ECU to fuel incorrectly. Very common issue on VAG cars.
I changed it with a original one , nothing changed :(
Was it a genuine VAG revised green CTS?
Yes , I bought from authorized service of skoda
Watching your video VCDS is showing CTS reading of 103 C is high, I've never seen more than about 92 C on a healthy VAG engine. Don't know whether that is being caused by it running lean or a faulty CTS ?? but I'm sure the ECU is going to be leaning it out at that sort of temp. Is the temp gauge showing 103 C too?
Edited by pauldazzle
no temp gauge stable at 90
in video I didn't look the temperature  ? where did you see ?
  • 2 years later...
@veracocha Did you managed to solve the problem ?
What was causing in the end for Lambda idle self adaptation to be at %20 ??
