some vcds adaptation. need help !
hello.
i tried some adaptations on my 2014 vrs with vcds 15.7 whick is it slightly different from previous versions. And is a combination of languages english-german.
1. disable start/stop -> i changes the value from 7.6 to 12.1. it's working ok, it does not stop any more when the car is stopped, but when i make an autoscan with vcds i receive a malfuction to alternator.
2. tried to enable the second rear right foglight, but it cannot be changed. i tried to change the A 27 value from 0 to 100 but i keep getting a message that is invalid. the AB 27 value is not 0, but 17.  NEED HELP!
I would also like to change:
1. turn signal indicators to us signal lights to 30%
2. use front fog light for cornering.
Help please! :)
Thank you!
2) in German version it is: Leuchte27NSL RC6-Lichtfunktion A 27 to  "Nebelschlusslicht wenn kein Anhänger gesteckt"
Dimmwert AB 27 to "100" setzen
