Door courtesy lights
Has anyone else ordered the LED door courtesy replacement lights from SuperSkoda?  I ordered them but it appears as thought there has been a change to them at some point?  The ones in the car from the factory have a festoon lamp inside under a lens, but the Super Skoda units appear to be a sealed unit with a plug base on the end - which is how the boot lights work.  I swapped over the boot lights no problem but the door units have me flummoxed.
My only guess is that there has been a manufacturing change somewhere between the SuperSkoda units being designed and my car's production - its an MY17.
Anyone else have experience here?
I have changed all 4 door courtesy lights on my MY17 L&K with LED replacements from SuperSkoda. No problems, no festoon bulbs - all 4 units have plug base on the end.
Hmm, interesting.... Maybe the whole unit does clip out and I only unclipped the lens or something.  This requires further investigation...
Yes if you saw the bulb then you had only removed the lens, you need to remove the whole lot.
  • 4 weeks later...
