Multi Function Steering Wheel
The right hand scroll wheel on my car has stopped working and is very annoying as I cant scroll through the menus in the phonebook or check things like fuel consumption - has anyone else had this problem? Thanks for any feedback.
Mines ok, warranty job, I just hope they can get hold of new steering wheels easily enough.
I remember someone had problems with parts coming through after having a bump.
My mate has had this issue on his Octy 3.
My right hand side scroll button is OK, but for the life of me I can't get a proper reading on average fuel consumption. It fluctuates between say 12 mpg and 95 mpg, constantly moving and then. - - - ( no reading ). Is it something I'm not doing, or is it a fault ? Many thanks for any advice from a great forum.
Are you sure you have selected the 'average' consumption? It reads as thought you are on 'instant consumption'.
Thanks Sagalout. Will check that out later.
Sounds like instantaneous, should range from 300 to --- on a diesel anyway.
The next menu 'up' is either Long Term, Since Start or Since Refuel.
Edited by FelisBengalensis
Thanks Sagalout & Felis. Forgive me, but how do I move the menu " up " . I know I'm sounding thick, but just can't seem to do this. Thanks again.
You scroll using the thumbwheel. You push it to swap between things like car data, navigation info etc. Then once you have the section you want then you scroll using the thumbwheel.
Perhaps also you need to go into the infotainment system on the big screen in 'Car' and make sure you have selected the options that you want to appear in the maxidot. You can choose what is available to see on the maxidot. That may be why you cant see it if you have been scrolling already.
I had to get the infotainment manual (n.b. NOT the car manual), sit in the car and go painfully thru the page to get it into my head.
hth
Edited by Sagalout
It certainly does Sagalout. Many thanks again for your help. Much appreciated.
Did you get the scroll wheel fixed? The one on my Fabia is playing up now.
