LED Lo Beam?
So i've decided to upgrade my Low beams ( dipped) and my search came down to plug and play LED kits. i've seen it's easier to mount then Xenon kits.
i have looked all over the internet and came across two intresting models:
https://www.auxbeam.com/headlight-bulbs/88621845
and:
http://www.ledperf.co.uk/h7-high-power-led-conversion-kit-p-11585.html
The problem is, im not sure if they will fit. i've looked under the hood and the clerance is really tight. the fan on the bulb are 4.25 cm tall and im not really sure if they can fit. any suggestions?
If there isn't sufficient space to fit those, give up on the idea and fit Phillips or Osram high output Quartz-Xenon bulbs?
