New Car need help with dash cam fitting with kessy!
Hi can anybody help. I have just taken delivery of a CR190 L&K and wish to fit my dash cam using an add on piggy back fuse. Previous threads suggest using fuse 47 rear wash/wipe but this is not possible as there is a huge fuse in the way. I cannot find an ignition only live fuse as my multi meter shows all fuses I have tried as permanent live. Could this be due to the Kessy system as you cannot turn a key 3/4 of the way to turn the ignition on with a stop/start button. A similar problem arises when you wish to park the front wipers to clean them as you have to turn the engine on and off quickly and flick the stalk. All help would be greatly appreciated. Many thanks
Take a look here for where others (myself included) have taken the feed from.
Edited by Gizmo68
helps if I include the link!!
Many thanks for that I shall try again when the weather improves!
You only have to have the ignition switched on and off. See here.
Again many thanks for the info
