Warm start problem
Hi since coming home from holiday my car takes a lot of cranking to start when hot??
starts firs turn of the key when cold just hard to start when hot.
i have also had after a warm start the radio part at the top of the computer turns red
turn engine off and restart and that goes back to normal colour???
1.9TDI
anyone know what the trouble could be???
im thinking injector or maf problem??
cheers in advance
Rexob
Battery going flat?
PD Engines have a dodgy Start IQ Map which if the coolant is over 70'c it won't start injecting fuel until the engine cranks over 280rpm
As above - almost certainly battery.
Its not the map that's dodgy, its the weak starters that are the root of the problem.
thanks guys the battery is fine i think but will look into it
as i said its been fine until a couple of weeks ago
havent noticed any difference in the battery power at all
thanks for the help
so do i go for a better starter or new battery ????
Edited by Rexob
You could try using jump leads when the engine is hot to simulate a better battery.
Simulating a new starter is a bit more difficult.
Edited by Tdi1.9
Try what TDI1.9 suggests first.
You can get the Starting Maps corrected during a remap and I always do this on each PD car I buy :)
Do this and if it doesn't improve it you can either fork out for a new starter or do what badger suggests and get the map changed to work around the issue.
yeah though of this last night but glad you had the same idea
will give it ago and let you now what happens
never had a remap done who do you use badger89 ??
Faboka remapped my last car and I've done the last two myself.
Don't believe he does these anymore?
Blacksmoke seem to be well regarded on the ukpassats forum...http://blacksmoke.co.uk/
tried the battery its not that or the starter motor!!!!!    its like the fuel has gone back to the tank so thought it may be return valve
Faulty CTS?
if it was a fuel priming issue it would be worse first thing in a morning when cold, not right after it was running. have you checked the timing?
Battery going flat?
whay if the temp sensor isnt working properly cold that cause the problem???    i as because the temp sensor sometimes doesn't work i tried looking at the plug under the overflow and moved it about and the car did start even warm???
no i havent,, ill have to get my mechanic to have a look i think
