Fabia VRS miltek exhaust
Yeah you could be right, im changing my plugs this weekend not sure whats in at the moment, but im puting denso iridiums in it.
I picked my miltek exhaust up on demon tweeks there a really good parts supplier.
£535 without fitting, but its gunna be deliverd to me and i can fit it myself anyway.
Yeah fair point. Whats the best brand thats recomended for the engine ?
Edited by BigDan123
Wow I thought I was impulsive!  I have sneaky suspicion you may have just bought this car?  Anyway hope it works out well (especially with the milltek)
For Oil follow offski comment above. Im goin for Tesco 5w-40 for top ups.
Petrol always super unleaded. I have been on Shell 99 but have recently switched to Tesco momentum. Couldn't really tell the difference tbh.
Will update regarding success of fixes in a month. Good Luck!
Edited by Kobayashi
Haha yeah it was a tad impulsive, i was getting some new front and rear discs and pads on demon tweeks, and while i was there i had a look at exhausts and thought "why not" and and added it to the basket.
I might start using cheaper oil then since it doesnt make a difference if i use the dear shell stuff. Ive alway use shell super unleaded aswell.
Cheers bud.
Maybe give Tesco Momentum 99 a try if you are near enough a station.
Maybe the same or similar Detergent Package to Shell V-Power Nitro+, then again maybe not, so a bit better with an engine where Bore Wash can be an issue.
The Winter Formulation is now in filling stations or should be.
Both might well be 99 ron minimum but even if Tesco Momentum was £2.50 a tank more expensive than Shell V-Power Nitro+ i would still use it.
As it is it costs less and is at least worth a try IMO.
Ah nice, il have a look see where my nearest tesco filling station is. if theres one near by might give it a try.
Hi Dan,
How is your car doing, had my Milltek fitted Denso Spark Plugs, weights removed and GFB dv+ fitted sounds really good,
Dyno run stock no mods was 173.9BHP and after custom tune it got 193.4BHP
http://www.briskoda.net/forums/topic/417563-cave-fabia-vrs-mk2-future-mods-oem-upgrades/ (Post#15)
Fitted the miltek exhaust on saturday sounds really good not too loud but definetly loud enough to tell the differnce , has a nice bassy grumble when idling and at low revs
pops loads when you give it some. Going to be fitting my forge blow off valve soon and its going garage for a diagnostics in january as it keeps missfiring and the engine waring light comes on when ever drive it hard the EPC and engine warning light come flashing on for 30 seconds then go off.
Please just give the Forge BOV a miss. They are useless.
If you have the Plugs & Coils now sorted, the Induction & the software with the latest running you need a diagnosis done.
There must be a sensor or some other issue,
& you want to be sure it is not a valve issue.
A biggie would be Water Pump / Supercharger Magnetic Clutch failure,
so do not put off finding why you get the EPC light illuminating,  best not boot it hard until you get a diagnosis and the issue resolved.
Edited by Offski
Hi Dan,
Hope you get the EPC light sorted did you change the coil pack ? It was coil pack 3 on mine 6 months ago, a good diagnostics should tell.
The milltek sounds reasonable In D : nice Low grumble, manual sounds amazing (when you want it too)
You would be better fitting a GFB dv+ than the forge. I got one off a forum member on here
Yeah i hope i get it sorted too its a right pain this missfiring. I havent changed the coil packs but im looking at getting the r8 coil pack set with the adapter there about 200 odd quid depending on what colour you ghe the adapter in but il definetly be getting them before i get it mappoed. But yeah it should be having a full diagnostics when it ake it to this garage hes supposed tro be one the best vag specialists around my area suposedly anyway we'll soon see haha. m
Yeah really impressed with the miltek thounice low grumble and good sound through manualy like you said. Ah i didnt know about the GFB is it any good , ive allready bought the forge one but ive heard good things about it and for 172 quid it cant be all that bad.
Who tells you these good things, like that a Forge BOV is any use with a 1.4 TSI / TFSI Twincharger , or do you mean the DV+?
they are good for a remapped car.
Can they not tell you why your car is misfiring or playing up?
Edited by Offski
Well ive allready got the bov so ill at least see what its like fitted i may end up selling yet.
yeah i am defiently keen to find out what it is as soon as possible im booked in the garage in january so will find out then hopefully its a sensor like you say. and yeah i wont be driving to hard until i find the source of the problem . i dont want to knakcer the car any more than it may allready be.
i wont be fitting the bov until the issuse are sorted aswell.
These cars run well even on 3 cylinders as long as not hard acceleration and no S mode, I did it for a month, coil pack 3 had gone spark plug 3 tip broke off, coaked in oil, this is what brought me to forum and the oil consumption saga...
  • 4 weeks later...
Had car in garage at weekend, blow off valve fitted no issues with it so far and mechanic has said missfires are down to the coil packs three off them are knackered so ive ordered 4 bosch ones i thought id just raplace all 4 instead of 3.
That's good news then, if your running decent plugs as well just keep an eye on them.
yeah ive got the denso iridiums in at the moment so just going to wait and see what its like with the new coil packs in and get another diagnostic run to see if its resolved the problem
Are there any uprated coil packs, or does everybody go for bosch ones?
I also bought carista OBD2 dongle off amazon so you can monitor fault codes using either carista app or torque pro. Slots into the ODB2 slot near fuse box - connect to android phone / tablet
Worth getting if you just had issues with miss fires etc...and made changes.
A few people have used these Audi ones http://www.tmg-performance.com/en/products/ignition/r8-335.html
Im still on OEM ones apart from coil pack 3 problem beginning of last year. Running stage 1 now with no issues so far.
Should any of the others packs go will likely replace with these 'Audi' ones
