Confusing Fuse Panel Fabia VRS MK2
Will have look tonight -  manual is at home.
When you say labels i just copied the text from manual shortened it then pasted it on top using powerpoint using the red photo top of page, then re saved as Image file
  • Sponsor
Yep, that's what I meant by labels, the text that you added. :thumbup:
Sorry for butting back into this topic again, but Wino, I did create a erwin account a few hours ago (probably created one 10 years ago as well!), tried to buy an hour but both of my credit cards are being declared as invalid - which seems a bit strange!  I've tried going through all the business ts and cs and can't find anything that would indicate that you need to wait for a set time before buying from Erwin, any clues?  Both these credit cards have been used to buy online in the past.
  • Sponsor
Try later/tomorrow. Not sure whether I tried buying time the same day as I registered. PM me if still having trouble (or email them) to save further OT. :)
There is no mention in my manual of 'fabia anglicky nn? but the fuse diagram is listed as B5J-7023H and is the same as top of this page
  • Sponsor
On the very last page of the pdf one I've got is this 'edition' info (I guess this means May 2009):
Edited by Wino
hi yes found it on back of manual it Says:
Fabia anglicky 05.10
S55.5610.06.20
5J6 012 003 GH
Does anyone have high res Image of the OEM fuse box as below. I have now got the symbols in correct place by mirroring the rows, but I would be able to make a perfect OEM version with a master. This took me 10 mins. I would have to re put the numbers on.
Edited by Kobayashi
A Final version with no's corrected. This will suit RHD cars, This took some doing!
Fuse Panel Correction RHD (5J0 010 743)
Not my greatest cut & paste work, if someone comes across an original HD photo I can mirror and flip straight lines easier. This version going in my VRS anyway.
Edited by Kobayashi
  • 1 year later...
Bump for the member with the DRL / Sidelight problem with a vRS Fabia.
If you search there are other threads.
