Bloody 'ell
Sounds good, I wonder how much it is to fit it?
Love the customer feedback comments :D
I may as well add this to my list of things to do - as well as the 312mm discs, strut brace and new front shocks (uprated).
go on you know it makes sense :D
hahahaha, love the comments on it :rofl:
I had my car hoisted in the air at the weekend and I got to inspect the ARB up close and personal. It really is a nice bit of kit. :cool: If I had to criticise in the smallest, niggly way I'd say the way it attaches to the beam looks a bit brutal, but I'm sure its effective. :cool:
Mine was cleaned off with a wire brush and thickly coated in black underseal. :D Was starting to go a little rusty on the surface as mine was the "experimental" one, and hadn't been coated green like you normally get. Oh, and mine was fitted as I was there anyway. ;)
Can i just reask is anyone running this with 17s?? Thanks
Jason (above) has 17's albeit it's not a vrs and so does shift iirc
I have 17s. To be honest, alloy size is pretty irrelevant to the rear ARB. :)
It doesn't shift bad, considering its a non-vRS Fabia.
Nice one - getting the wheels this weekend yay
really nececcary??
If any of you guys are up for this, could you add your names to the list?
Its just that, it'd make the difference between a GB discount and 'a no-goer'......Oh, and I can only afford one mod at a time......so if this is 'on', something else isn't.......if you get the idea.......sorry for the ramble.....
John. :)
Sounds good' date=' I wonder how much it is to fit it?
Love the customer feedback comments :D[/quote']
Fitting it yourself not an option then ?
...also increases the back off oversteer effect...adding to your driving pleasure....
Don't need that, my Kumhos do that more than well enough already... :(
hahahahaaa!
i'll put a fiver on you having one of the jabba ARBs on your car within the month....
hahahahaaa!
Not before I've changed the tyres... and fitted the gauges... :D
...or recovered from xmas & new years, repairing the key damage to the Furby,
Oh dear how easy is that gonna be to copy and knock out for 50 quid on ebay.
Doubt the demand is there TBH - unless someone from on here does it, in which case someone else would probably bring it to the attention of Jabba...
After seeing it up close, with the bushes and the design of the bar, and the mounts to the suspension bottom - very tough indeed. I think the cost of the steel bar, and the work involved to make it that shape is
