Setting passager mirror for revesing.
I collect new skoda today and first have problem.
After setup passenger mirror for reversing,  mirror is changing position when i enable reverse gear but after when i enable 1st gear mirror does not come back to normal position.
any ideas?
Edited by Szmulik
Maybe a problem then.... When the mirror control is set to the left mirror it should change position when you select reverse. It returns to the normal position after you reach a few mph not when you select first gear... At least with the DSG.
^^ Correct. Not sure of the speed but it's about the same time the doors auto lock IIRC.
If after you've reversed and stopped - switching the mirror control away from L will revert the mirror back to normal position.
thank you,  will try it tomorrow.
