2010 Octavia 1.9 TDI - Maxi Dot / Computer
Hi all
Got myself a 2010 Estate with the good old 1.9 TDI (Tho a BXE but I will take the risk and change oil every 6 months). Need to get under it and check about DPF but Im SURE it has one as all European sold Diesel cars after 2008 had to have one tho this forum everyone says only the 4x4 ones did.
Its proper budget spec....... I dont mind but doesnt even have the trip/mpg computer. I know the Maxi dot seems had to add to a face lift (Impossible back in 2012) but what if I want the mpg instant and odometer reading? Can I get a different stalk (with buttons on end to cycle through) and code it with VCDS?
Here is a VCDS log if it helps?
Sheldon
Sunday,04,December,2016,11:18:55:32772
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
www.Ross-Tech.com
VIN: TMBJS21Z2A2045227   License Plate: OCTAVIA
Mileage: 103420km-64262mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: TMBJS21Z2A2045227   Mileage: 103420km-64262miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 TB    HW: 03G 906 021 AN
   Component: R4 1,9l EDC G000SG  2047
   Revision: --H11---    Serial number:
   Coding: 0000071
   Shop #: WSC 73430 790 00999
   VCID: 72E0A13D6D2F25D2CF-8026
1 Fault Found:
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 103154 km
                    Time Indication: 0
                    Date: 2011.03.13
                    Time: 07:59:29
             Freeze Frame:
                    RPM: 924 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.78 V
                    Bin. Bits: 00101100
                    Temperature: 13.5°C
                    Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AQ    HW: 1K0 907 379 AQ
   Component: MABS MK70M          0105
   Revision: 00H32001
   Coding: 0016641
   VCID: 0102FEF158890E4AC6-8054
No fault code found.
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 H    HW: 3T0 820 047 H
   Component: Climatic      130 0203
   Revision: 00005001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_SK35.rod
   VCID: 346C67259FBB6BE21D-8060
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 G    HW: 1K0 937 086 G
   Component: BCM PQ35  M+  103 0541
   Revision: 00103 AE
   Coding: 48180AB8B0050CB04010008011000164010000AE424D81605C0440000000
   Shop #: WSC 27023 576 88146
   VCID: 346C672597BB6BE21D-8060
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 12090  22  0601
   Coding: 00D7B7
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 20
                    Reset counter: 200
                    Mileage: 103158 km
                    Time Indication: 0
                    Date: 2011.03.13
                    Time: 14:37:28
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02746 - Bulb for Daytime Running Light; Right
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 20
                    Reset counter: 200
                    Mileage: 103158 km
                    Time Indication: 0
                    Date: 2011.03.13
                    Time: 14:37:28
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2FSZSS
   Coding: 0020788
   VCID: 3D7A420164F1AAAAE2-8068
   Subsystem 1 - Serial number: 6332MSME4B71216BE
   Subsystem 2 - Serial number: 6342MSME4B112E7DP
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000032
   VCID: 030EF4F942951C5AD4-8056
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 903 D    HW: 1Z0 920 903 D
   Component: KOMBI         H21 0110
   Serial number: 00000000000000
   Coding: 410300
   Shop #: WSC 73430 031 00999
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
   VCID: 36685D2D89C779F223-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 5223
   Revision:   H16       Serial number: 4120K0991605EB
   Coding: E9801F06000202002303
   VCID: 66C8CD6D51E7C97253-8032
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 96
                    Reset counter: 233
                    Mileage: 103150 km
                    Time Indication: 0
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 233
                    Mileage: 103150 km
                    Time Indication: 0
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H21 0110
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2114
   Coding: 0000564
   VCID: 489423D53B33FF0241-801C
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 68     2901
   Revision: 00H17000
   VCID: 2F666849BE9D483A60-807A
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000564
   VCID: 479620E9362DF07A48-8012
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 G    HW: 1Z0 035 161 G
   Component: Radio-SWING   008 0021
   Revision: -----10S    Serial number: SKZ4Z2J1122742
   Coding: 000002000001
   VCID: 3260613D6DAF65D20F-8066
End-------------------------(Elapsed Time: 01:42)--------------------------
If it's mega basic without even a trip computer, I'm sure that you'll need to swap over at the very least the cluster and stalks.
No UK supplied 1.9 in the Octavia had a DPF, even the 4x4 1.9 TDI has no DPF.
Thanks Eddy. Is that right part number, J?
The cluster although basic with just temerature shown in middle large, it is the large display White and black. (Il take a photo tonight)
Yes, that is correct one
You have a basic cluster, but it can still be coded to provide you with several trip computer options
Average Mpg
Current Mpg
Average Speed
Range
Distance
Perfect thats all I wanted.
Coding the cluster to the car is only required if you want to upgrade to a maxidot
The cluster you have now can have the trip computer function enabled with VCDS in the long coding
Cheers guys. Yes I dont need the colour display happy with my White and Black, so I can code with my VCDS
He doesn't need to replace the cluster Mike. His existing one just needs long coding to show the trip computer.
