Steering wheel buttons < > failure
I have found one failure with steering wheel buttons - left side < > buttons don´t work. If I make hard reset to Columbus head unit, then buttons work approx 2-3 times and that's all. Does this fault is similar to somebody? Do I have to decode with VCDS or update SW? My Columbus SW is 40XX and car is Superb (2012).
I believe, the problem is more electrical matter, rather not just cleaning the buttons or buying new ones. Seems like there is some malfunction between buttons and head unit communication. I haven't find solutions to solve it.
I appreciate any advice you may have.
Is it just the < > buttons? Do the volume button/s work okay?
It sounds like it may be a gateway issue with the Columbus, have you had any software updates done previously, or do you now the history of the unit?
I've a few units here which have failed an update on the Gateway stage, and they display somewhat similar tendencies which can be rectified by a reset, until the next time they decide to misbehave. Does the unit turn itself off periodically when driving?
It's only < >, all other buttons and volume scroll work well. I bought this car one year ago and it seems, that previous owner had retrofitted Columbus. I haven't done any software updates (only updated map) and I don't know history of the head unit (3T0 035 680B ). There is no malfunction with my Columbus and it will not turn itself off when driving.
Edited by Lutz
You might try a software update or reinstall then, but if the unit is misbehaving then it might make it either worse or better. No way of knowing until you try it I reckon.
The fact that you can make the buttons work via a reset points to it being something along the lines of missing communications between the head unit and the car.
