Aux drive belt length?
I bought a new auxiliary belt from ECP and it seems to be way too short, does anyone know the correct length for a 2006 bwa Octavia vrs tfsi?
Sadly I can't read the writing on the old belt.
The one they supplied is 6pk955 and it's listed on eBay as fitting my car.
I never even tried fitting the new belt as it looked way too short.
Richie.
Conti Catalog Lists 2 different aux drive belts for BWA engines for some reason. Edit the (-AC) must mean without air con so you need the 6PK1054.
6PK1054 4.png Active  ALT, (AC), MTR-CODE: BWA  pic.png 6PK1120 4.png Active  ALT, (AC), MTR-CODE: CCZA  pic.png 6PK955 4.png Active  ALT, (-AC), MTR-CODE: BWA
The numbers are the belt length in mm. So 6PK1054 would be 1054mm against 6PK955 955mm.
ProfilePKNumber of ribs6Height (h) [mm]5Rib spacing (s) [mm]3,56Length [mm]1054
Edited by TheClient
Thanks for your help mate, I've looked back at ECP's site and the one I bought actually states the one I got is for non aircon, I wasn't even aware you got a bwa engine with no aircon.
Thanks mate.
