Bulb ou warning with no bulbs blown?
Hello all.
Not been on here for a long long time.
I have still got my Fabia vRS, lately it's started showing a bulb warning.
It beeps up after a few seconds of starting and stays on with all the lights off or just sidelights on. I've checked all the bulbs and all work all are std bulbs.
It goes off if you put the headlights on though or start up and switch them straight on.
Soon as you go down to side lights or switch them off you get the check lamp come on.
Any help would be grear
Tia
Do you have xenons factory fitted? It's been reported that the wiring loom to the rear level sensor has rubbed through to the exhaust heat shield causing a fault.
Yes I habe.
mine did this in the damp and went of when car was warmed up .
Cheers. Mine does it all the time. Wife drives her. It was intermittent but only for a few days.
I'll have a look when I get home.
  • 3 months later...
bringing this back up.
This warning is still coming up. it is now on all the time till you put the headlights on.
I've checked the level sensor wiring and it all looks fine.
I am getting no codes on VCDS
there is no bulbs out at all.
Warning comes on with the ignition and stays on when all lights are off or side lights are on.
goes off when the headlights are on.
any more thoughts guys?
