Bluetooth 3C8035730E in FL Mk2 Bolero 1Z0 035 156 G
Edit: Car has Maxidot
Will this combo definitely work? Recent thread on similar subject suggested poor compatibility with some Boleros.  The bluetooth module is obviously a lot later than the car (and Bolero Unit).  2011 MY Car, Bluetooth 2014.
1. Any functionality issues?
2. Is the enough space behind climate control for the module or is foam surround to mount under drivers seat required?
3. Where does the internal GSM aerial get mounted - does it work?
Here is scan detail for the Can BUS and Radio
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 G    HW: 1Z0 035 156 G
   Component: BOLERO        015 0029
   Revision: -----29S    Serial number: SKZ4Z3L1125251
   Coding: 090004000001
   Shop #: WSC 73430 790 00083
   VCID: 36632329813F9B8E94-8062
No fault code found.
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 250411F1002378
   Coding: 352303
   VCID: 306F1531635BB5BECE-8064
Edited by TheClient
1. Any functionality issues? No, Should work fine
Under Drivers or Passenger seat if you want to do it properly
There is space under the top of the dash Cubby bin (foam holder not required)
Anywhere on the A-Pillar should be fine
Brilliant - thanks for the reply.
It's also worth checking the SW version on your instrument cluster.
Earlier versions are missing some of the icons that 3C8...E modules use.
Arr, ok. Here it is. Doses this help or do I need to look at a sticker on the unit itself?
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 943 L    HW: 1Z0 920 943 L
   Component: KOMBI         H20 0420
   Serial number: 00000000000000
   Coding: 410A01
   Shop #: WSC 73430 031 00083
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 428B4FF9D5F7372E28-8016
Edited by TheClient
That will be fine
Hi,
i have Skoda Yeti my2011 1.8 TSI 4x4 EXP with maxiDot and Bolero.
I just installed BT module 3C8035730E and ceded by Vag Can Pro (myself. i'm not professional)
I'm happy with it, but Vag Can Pro showing some errors:
(translated from czech. could be difference in some words..)
Adressword  : 77
VAG number: 3C8035730E
Description J412  Phone
Advanced mode UDS, EV_UHVPremi 002709
SW version: 0983
Coding: 020000000100000000000101
Errors found
905313 Missing description in box ODX
905211 Missing description in box ODX
D01300 Missing description in box ODX
Could somebody help me?
What is wrong? Everything works.
Solved
bad coding
