ECU Query
Hi all,
I recently posted that my ecu was fried and that it needed replacing. However I've noticed some interesting behaviour from the ecu lately.
The problems I have been having are happening less frequently and I have noticed that when it rains, is cold and damp or when I wash the car I get the problems that have been linked to the ecu. Basically the coil plug light won't show on dash and the car won't start. But after a few turns of the key it does start.
Is it likely that the water is getting into the ecu and causing a short and if so is there any way of waterproofing the ecu instead of going for a replacement? Has anyone had a similar problem? Any help would be appreciated.
Keith
The ECU is in the "plenum chamber" I think Skoda call it. The area where the wiper motor is. It is raised off water collection height by a stand and is normally pretty well sealed with a jacket. You could google or search for some images.  That said, I suppose it would not be impossible to have a water ingress problem.  I seem to recall a few others being reported in the time I've been reading here.
Sounds like you need to get in there and have a look.  Probably send the ECU off for repair. And check the water tightness of the jacket and connecting looms and look for any water corrosion ingress evidence.
Also a good time to clear the drainage holes for the area (which drain down into the wheel arches).
Not a big job to get in there but you need to remove wipers so a wiper arm puller helps.
Thanks for the info.
Its probably wishful thinking on my part that I won't need a big job done on the ECU or a replacement but I was intrigued by the fact that the problems appear weather related.
The man who looked at the problem when it first started has charged me a fortune to just 'diagnose' the problem so I'm slow to give him any more money to be honest.
Your help was appreciated
