Custom maps
Hi
Been a while since I've been on here :emoticon-0101-sadsmile:
But need a 'mapper' I've tried faboka but seems his sites down and emails aren't working?
But I've got a vw caddy with edc 16 ecu ans dreaded bls engine that threw a rod, so it's Got a asv engine with pd130 injectors, 3 bar map, hybrid pd140 turbo with pd170 wheel, decat, open filter etc, it's running using the edc electrics (crank sensor mod, cam pick up changed etc) but chucks smoke out and hunts rough etc, anyone know who can sort a map out like John at hidden power used to? Just to get it to a proper rolling road set up if needs be
Thank Dan
I would try oscarli
Seconded
sarah
if you can dump hex of ECU, I can check out...it most likely have same ECU as my car that I calibrated myself
