Damo's Fabia III (Updated 12/10/17)
22 minutes ago, Damo said:
Join Yorkshire Skoda’s on Facebook and also Sheffield Dubs
Always having local meets (unlike Briskoda unfortunately)
Damo can I ask how your mpg Is like in the new Octy? If driven sensible (sometimes) :D
  • Replies 106
  • Views 21.2k
  • Done a few little upgrades.   First of all sorted out the interior lighting.   Changed all bulbs to LED's which has made a big difference.   Unfortunately i managed to br
  • Well, got the plates on. Delighted with the whole process to be honest. Bought them on the DVLA website Wednesday, ordered the plates and holders which came Friday as well as the certificate of entitl
  • After spending most weekends detailing other peoples cars, finally spent some time on my own.   Snowfoamed       2BM Washed with G3 Body Prep Sham
Just on my 5 miles to work I get about 32mpg
if I go on a run I can see approaching 40
Not too dissimilar to what I was getting in the Fabia.
Done some nice mods to the Octy now.
19” BBS Alloys with Rainsport 3’s, Lowered on H&R springs, black grill and black badges, LED number plate lights off an Audi, all interior LED’s etc.
Holding off on the power upgrades for now (but it’s hard to resist as £400 gets you to 300bhp)
Yeah found it a few days ago. Was going to go to worksop tonight but car not delivered until next week
3 hours ago, Damo said:
Looking absolutely mean! Nice mods btw. I'm not afraid to admit I am well gel! Maybe I will own one one day
  • 5 months later...
On 14/07/2017 at 18:21, Nathanb93 said:
Just fitted my new sunstrip a few moments ago. Added a bit of pinstriping as i had a load left over from when i did the rest of the car
Im not too sure about the placement of the pinstripe on the out side, i think it might look better about half an inch up from the bottom instead, like on the inside.
I have a couple of small skoda logos on the way that are 80mm long to put on the left side both inside and outside
What size sun strip did you end up going for? Looks awesome
  • 4 weeks later...
On 11/02/2017 at 10:01, Damo said:
Next job was to sort out the Aux cable.
I hate seeing cables trailing everywhere, so I lifted up the rubber mat in the cup holder, drilled a small hole and fed the cable behind the console and up through the hole. Then I made a small hole in the rubber mat, stretched it with some pliers and fed the cable through. That way when the rubber constricted it stops the cable moving on its own and is virtually invisible.
And with mat in situ
Then i bought a Belkin Cup holder Phone mount (as they will take my iPhone 7+ OK) and fed the wire through the little hole in it
And when the phone is sat in it, the only wire you see is a bit out the Aux port and a bit going in to the phone.
My OCD side is comfortable with that.
Sorry to drag up an old post.
I have this phone holder and when i get my car i will be doing the same, did you have to drill the cup holder or just the rubber mat?
Was it easy enough to run the cable behind the trims etc
