280ps service interval
Firstly I'll say that my MY2016 280 TSI is the first car I've had that is within its manufacturer's warranty and therefore the first car that I am having serviced by a Skoda dealer - previously I've always done my own. And I am naturally suspicious of dealer servicing!
So I had the oil change service done at around 13,500 miles with about 1000 miles still to go before it was required. Now a month and about 700 miles later, the service display is showing next oil change due in 9600 miles / 365 days (although it varies a bit as I drive). To be fair, the first 9500 miles were driven by someone else as I bought the car at 6 months old. But most of my mileage is out of town fast main roads 80+ miles (no traffic - this is Scotland!) so its not as though I am doing endless short journeys in town traffic or such like. The paperwork from the Skoda dealer says they put in "Mobil Super 3000 5W30" but not exactly which one. And I thought "Skoda recommended Castrol Edge"?
So my question is, why is the car effectively requiring an oil change at around 10,000 miles since the last one. Is it because the dealer didn't change the oil filter (they said they did) or put in the wrong oil, or is it just my driving style? And do we know exactly how the variable servicing detection works? - is it actually measuring anything to do with the oil filter pressure drop and/or oil condition, or is it just an algorithm based on the usage of the car / driving style?
No they simply put the car onto fixed servicing (12 months / 10K miles) instead of variable which it was previously on.
No I don't think so. The distance and days to go both change up and down as I drive. Like it was 9600 and 377 days, then after a couple of days of around town driving down to 9200, 365 days, now after a long trip it's back up to 9500. Surely if it was fixed servicing it would just be a continuous count down?
Anyway I do have a VCDS so presumably I can confirm or refute that somewhere?
Edited by nicknorman
I took a controller map, which shows "good oil quality" is set but some rather short  maximum times compared with the manual's claims of up to 30,000km. Its not that I particularly want to stretch the oil changes to the maximum - on a car with an engine like that I'm sure more frequent oil changes can only be a good thing. Its just that I feel the dealer may be trying to con me a bit by reducing the time before I have to give them more money!
;SW:3V0-920-910   HW:3V0-920-910 ---  Instruments
;Component:KOMBI         306 6422, Coding:27A5081AFF84A600018B6A0B5001000000000000
;EV_DashBoardVDDMQBAB,009046,EV_DashBoardVDDMQBAB_009_SK37.rod
;Tuesday,07,February,2017,10:53:47:18227
;VCDS Version: Release 17.1.2 (x64)  Data version: 20170131 DS267.1
;VCID: 6ED7CCA9B1D0363100-803A
IDE00295-Oil temperature display,On
IDE00301-Distance,22901 km
IDE00342-ESI: Resetting ESI,no warning
IDE00343-Language version,English
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset
IDE00345-MAS12879-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset
IDE00499-Display correction of consumptions and operating range,100 %
IDE00500-Hour,10 H
IDE00501-Minute,53 min
IDE00502-Year,2017 yr
IDE00503-Month,2 mon
IDE00504-Day,7 d
IDE00510-ESI: distance driven from inspection,1269 km
IDE00511-ESI: time from inspection,35 d
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
IDE00514-ESI: maximum value of time between inspections,730 d
IDE00515-ESI: oil quality,good oil quality
IDE00517-ESI: soot entry,0 km
IDE00518-ESI: thermal load,3800 km
IDE00711-Trip recorder,not installed
IDE00819-Day counter,375 d
IDE00820-Activating and deactivating all development messages,not active
IDE00827-ESI: minimum value of time between inspections,365 d
IDE01153-SIA: maximum value of distance to service,15000 km
IDE01154-SIA: maximum value of time to service,365 d
IDE02489-Display depiction,Version 1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l
IDE03329-Driving profiled for range remaining,9.7 l/100km
IDE03346-IDE00301-Units adjusted-Distance,miles
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius
IDE03346-MAS02957-Units adjusted-Time,24h
IDE03346-MAS03032-Units adjusted-Volume,gallons (UK)
IDE03346-MAS03034-Units adjusted-Pressure,bar
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (UK)
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km
IDE03346-MAS13665-Units adjusted-Anhänge-/Stützlast Masse,Kilogramm (kg)
IDE03348-MAS01456-Speed warning-Speed,0
IDE03348-MAS01561-Speed warning-Unit,Miles per hour
IDE03348-IDE03348-Speed warning-,not active
IDE03349-FIX: Max. distance until next mileage-related inspection,32200 km
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection,1200 km
IDE03352-FIX: Time since last time-dependent inspection,35 d
IDE03372-Source for synchronization of time,GPS
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
IDE03867-Deactivate seat belt warning,No
IDE04169-Display correction of consumption and operating range: gas,100 %
IDE05930-Service notification in days,30 d
IDE05931-FIX: Reset value for next mileage-dependent inspection,0 km
IDE05932-FIX: Reset value for next time-dependent inspections,0 d
IDE05971-Vehicle Positioning System Interface Control Module,not installed
IDE06425-Roller test bench mode: functional,not activated
IDE06588-Ignition active message: actuator,Driver door
IDE06922-No-voltage display,No display
IDE07221-Cylinder shut-off,Display
IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km
IDE08247-Driving profile for range remaining LPG,10.0 l/100km
IDE11086-Service notification,30 d
MAS03685-Digital speedometer,Display
ENG117917-BAP_Debug_Mode_Release,not_released
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF
ENG119875-defuel_threshold,15 l
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,0A
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,46
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,03
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,03
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,11
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1F
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,5A
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,46
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,11
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,5A
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 3C
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 B4
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 DC
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,46
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0C
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
ENG119874-Gas_functionality,not active
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light
ENG119882-init_fuel_algorithm,No
ENG130585-Leaving_warning_delay,1.6 s
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0
ENG119825-Picture_Upload_Download,not active
ENG119876-Service_Key_Clear_All_Counter,Yes
ENG130584-Statistic_phev_mileage,5 km
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.6
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.0
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.0
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN
ENG112418-ENG99298-total_range_gas-State,not active
Why go to a dealer for servicing?  Go to a local, independent specialist and pay roughly 50% of dealer costs.  If you plan on changing your oil every 10K miles regardless of service regime then your annual costs would be cheaper than going to a main dealer for just a single service.
I'd prefer to do my own servicing, but since the car is an expensive high performance one in warranty I think its more sensible to take it to a main dealer. They charged me £135 which is not bad, and they did put in 504 oil (they say!). If the car was set to demand an oil change every 20k miles/2 years, I could do that at the dealer to keep Skoda happy and do an interim oil and filter change myself at 10k/1yr to keep me happy! That was my original plan before they scuppered it by setting the max interval to 15000km
Edited to say that of course I could just change the min and max values back up to 15000km and 30000km using VCDS but I don't want to mess up the warranty.
addition
Can you not ask them to switch the service regime to long life/variable when they carry out the next service?
Yes I can. But then I asked them to keep it on the variable service when I took it in in January! It was of course on the variable service originally when I took it in. I've been on the phone to Skoda customer service. They are "looking into it" with the dealer.
Edit: CS called back, apparently the dealer thinks they may have put it on fixed service interval "by accident" and are happy to change it back. It will be interesting to see exactly what changes on the Channel Map after they've done that.
So (if anyone is interested) I had the dealer change it back to variable servicing. This has thrown up a minor but confusing issue with VCDS since the "oil quality" setting is now set to "poor oil quality". When I put it back to "good oil quality" the service display shows oil change in 10,000 miles and when I set it to "poor oil quality" the service display shows 18,600 miles. So clearly the bit needs inverting in VCDS. Log file of the car after changing to variable servicing below - I've just included the relevant section.
;Wednesday,08,February,2017,10:47:03:18227
IDE00301-Distance,22919 km
IDE00500-Hour,10 H
IDE00501-Minute,47 min
IDE00504-Day,8 d
IDE00510-ESI: distance driven from inspection,5 km
IDE00511-ESI: time from inspection,0 d
IDE00515-ESI: oil quality,poor oil quality
IDE00518-ESI: thermal load,0 km
IDE00819-Day counter,376 d
IDE01153-SIA: maximum value of distance to service,30000 km
IDE01154-SIA: maximum value of time to service,730 d
  • 3 years later...
Hello Nick,
Have similar problem but with Czech Skoda Fabia Mk3 Hatchback, dealer by his stupidity reseted mileage to 15000km fixed and then was trying to restore to 30000km flexible, but every time indicator is reset, instead of 30000km I see 21900km or something:
IDE03351-FIX: Distance covered since last mileage-dependent inspection,700 km
IDE03352-FIX: Time since last time-dependent inspection,2 d
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km
IDE03350-FIX: Maximum time until next time-dependent inspection,365 d
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km
IDE05932-FIX: Reset value for next time-dependent inspections,365 d
IDE00510-ESI: distance driven from inspection,798 km
IDE00511-ESI: time from inspection,2 d
IDE00517-ESI: soot entry,2000 km
IDE00518-ESI: thermal load,700 km
If I understand the concept correct, I need to set SIA to 30000km and 365d and IDE05931-FIX and IDE05932-FIX to 0km and 0d.
Can you please show your current full adaptation map of 17th controller?
Thanks in advance!
Despite what the dealer tells you, all they can do is change from fixed to variable at that particular point in time.
If you've already covered a few thousand miles before realising then you won't get those back, the danger of course being you'll then exceed the recommended service interval.
I do not care what they say and do anymore. I just want to set proper values now and on the next reset to have it correct as the next oil change is going to happen soon.
I wonder, that if you try and reset the service interval before the car is actually calling for a service, especially when going from fixed to variable, that it now knows to factor in the mileage already covered since it was last reset / serviced?
Therefore instead of resetting to 30,000 km it is deducting the mileage you've covered since it was incorrectly set to fixed at the last service, hence it is showing 21,900 km instead of 30,000 km?
By any chance, have you covered 8,100 km since the last service?
If you reset the service interval when the car is calling for a service via the display, it then does not factor in the mileage already covered?
Just a thought.
Let it put me more clear.
I bought the car used. It was serviced and showing 30000 km/2 years for both oil change and inspection.
When I saw oil replacement message, I went to the official Skoda service and the guys did stupid thing by resetting the indicator by the instrument panel button. It was reset to 15000km/1year.
Then they started to play with ODIS and reverted to flexible interval somehow but oil change turned to 21900km max/2 years.
This is why I want to set it properly now as those guys are incompetent.
Why buy a £40,ooo car and worry about the cost of an oil change, when my 280 was new I changed the oil and Filter every six months for the first 18 months. Yes a bit over the top but this car I wan't to keep and it only does a small annual milage.
Mayoboat
Firstly I’ll say that I have moved away from variable servicing, and I rather wish I had done it sooner. A DIY oil change is very easy on this car, and costs me about £40. The car seems to prefer the non-longlife oil (less oil consumption, less fuel consumption).
i see from your post that you have the oil quality set to “good oil quality”. When I was looking at this I noticed that when I set it to that, the service interval went to the fixed interval. I had to set it to “poor oil quality” to get the longlife oil change interval. Clearly this is a bit of a bug that might have been fixed in your car, but did you try setting the oil quality to “poor”?
Ultimately you set the relevant distance to 30000km, 730 days and zero the thermal load and soot entry and, in my case, set the oil quality to “poor”.
It is all rather confusing and I think all the dealers struggle with it. I think this is why cars tend to come back from the dealers set to fixed intervals - that is much easier to do!
But as I said at the start, my recommendation would be to revert to fixed intervals and use 502 oil, not 504.
Hello Nick,
thanks for the reply, so if I understood you correct, after upcoming oil change I need to set:
IDE00342-ESI: Resetting ESI,reset
Anyway, when you will have time, I will appreciate your current VCDS log.
Thanks in advance!
On 05/04/2020 at 19:23, lprot said:
Hello Nick,
Thanks in advance!
Yes I think so, but please remember my original posts were 3 years ago and I have probably forgotten anything that I didn't write into the earlier posts!
I am happy to show you the VCDS adaptations of 17 but you do realise that I am now on fixed servicing? I think I used VCDS to reset the service interval last time I changed the oil.
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,75014 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,English ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,19 H,1
IDE00501-Minute,34 min,1
IDE00502-Year,2020 yr,2
IDE00503-Month,4 mon,1
IDE00504-Day,6 d,1
IDE00510-ESI: distance driven from inspection,8511 km,3
IDE00511-ESI: time from inspection,193 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,19900 km,2
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,1529 d,2
IDE00820-Activating and deactivating all development messages,not active ,1
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,9.1 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS02957-Units adjusted-Time,24h ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (UK) ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,55 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,32200 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,23100 km,2
IDE03352-FIX: Time since last time-dependent inspection,458 d,2
IDE03372-Source for synchronization of time,GPS ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,Yes ,1
IDE04169-Display correction of consumption and operating range: gas,100 %,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,0 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,0 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06425-Roller test bench mode: functional,not activated ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Display ,1
IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,10.0 l/100km,2
IDE11086-Service notification,30 d,1
MAS03685-Digital speedometer,Display ,1
ENG117917-BAP_Debug_Mode_Release,not_released ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,15 l,1
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,0A ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64 ,12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00 ,12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,46 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC ,12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,03 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,03 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,11 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1F ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,5A ,12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,46 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,11 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,5A ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00 ,20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32 ,20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64 ,20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4 ,20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 3C ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 B4 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 DC ,20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,46 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0C ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46 ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG119874-Gas_functionality,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s,16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km,16
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h,16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min,16
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG119825-Picture_Upload_Download,not active ,1
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
