Red light on door. Temprimental flashing?
When I lock my car sometimes the little red light flashes some times it just stays lit. Why is that?
Most likely to be the door controller at fault, could also check wiring. Before buying any parts, a scan is worthwhile.
probably one of the locks is failing, all locks are not in the same state,and are triggering alarm sistem.
Mikejay, did you ever get to the bottom of this? I have a slightly different issue, my little flashy light has stopped flashing.
Ive only just noticed my car has an led in the door card.
Im pretty sure it never flashes and my car has no alarm issues or fault codes.
20 hours ago, mikeholroyd said:
The other thing to check is whether the ultrasonics are working in the alarm system. Any incorrect flashing of the alarm LED indicates a fault in the alarm, not the door controller.
You really need to have a VCDS scan done, as any fault code will be logged.
Mike
Mike,
Scan below, a couple of issues but not indicated on immobiliser system where I thought it
VIN: TMBHS21Z6A2062983   Mileage: 166040km-103172miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 TB    HW: 03G 906 021 AN
   Component: R4 1,9l EDC  000SG  2047
   Revision: --H11---    Serial number:
   Coding: 0000071
   Shop #: WSC 73430 790 00999
   VCID: 72EA555D6D6323D1EF-8026
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0104
   Revision: 00H35001
   Coding: 0017665
   VCID: 7BF478793A296299BC-802E
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 M    HW: 3T0 820 047 M
   Component: Climatic      150 0303
   Revision: 00006001
   Coding: 0000000002
   ASAM Dataset: EV_Climatic A01005
   ROD: EV_ClimaBasis_SK35.rod
   VCID: 3978A271B8959089EE-806C
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
   Component: BCM PQ35  B   103 0573
   Revision: 00103 AF
   Coding: 48180AB8B05BB1C04008008011000024430000AE524D81605C4440000000
   VCID: 2D50862174DD3C2972-8078
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 29100  22  0601
   Coding: 00DFB7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
1 Fault Found:
02395 - Parking Light Front Right (M3)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 166048 km
                    Time Indication: 0
                    Date: 2017.04.12
                    Time: 19:27:24
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2GX9E.
   Coding: 0020788
   VCID: 3D70B66164BDACA9C2-8068
   Subsystem 1 - Serial number: 6332MSME4A4027075
   Subsystem 2 - Serial number: 6342MSME4C22293DJ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           056 0111
   Coding: 0001834
   Shop #: WSC 131071 1023 2097151
   VCID: 76E2694D010B3FF1C3-8022
   Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0012
   Coding: 00000130
   Shop #: WSC 00000
2 Faults Found:
00895 - Cruise Control Switch (E45)
            014 - Defective
00002 - Transmission Control Unit
            004 - No Signal/Communication
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 943 S    HW: 1Z0 920 943 S
   Component: KOMBI         H06 0608
   Serial number: 00000000000000
   Coding: 710900
   Shop #: WSC 00152 210 91233
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
   VCID: 4998D2B1E87500097E-801C
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0231
   Revision:   H16       Serial number: 4320K09B02028C
   Coding: E9807F06000202002303
   VCID: 69D8323140B5E0095E-803C
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0608
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADA4D3D8DB3EB1157-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2114
   Coding: 0000756
   VCID: 489ED7B53B7FF90161-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 68     3001
   Revision: 00H17000
   VCID: 31689A51A8E558C956-8064
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 479CD4893661F67968-8012
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        008 0053
   Revision: 0A001001    Serial number: SKZ1Z3I8176322
   Coding: 000004000001
   VCID: 3560AE419C8D74E90A-8060
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 326A955DADE363D12F-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3364905952F96AD924-8066
End-------------------------(Elapsed Time: 01:46)--------------------------
Address 09: DTCs cleared
Address 16: DTCs cleared
Address 17,1Z0 920 943 S,recoded (Long Coding),from,710900,to,711922,(00152/210/91233),
Address 17,1Z0 920 943 S,recoded (Long Coding),from,710900,to,711900,(00152/210/91233),
Address 17,1Z0 920 943 S,recoded (Long Coding),from,710900,to,710920,(00152/210/91233),
Control Module Part Number: 1Z0 920 943 S
  Component and/or Version: KOMBI         H06 0608
           Software Coding: 710900
            Work Shop Code: WSC 00152
                      VCID: 4998D2B1F07500097E-801C
Advanced Identification/FAZIT
     Identification: VD1-048
     Date: 29.06.12
     Manufacturer number: 5250
     Test stand number: 5771
Flash Status
     Programming Attempts(application): 0/0/2
     Successful Attempts(application): 0/0/0
     Programming Status: 00000000
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 1Z0 920 943 S
     Workshop System Name: J285
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A04114
Car Info
     Chassis Number: TMBHS21Z6A2062983
VCDS Info:
     Date: 29.06.12
Flash Status
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
Car Info
VCDS Info:
...... and you've had the car how long? :blink:,
Apologies, I just hijacked this thread! Shoot me now!!!!!
Ive had mine a year and a half or so.
I have never noticed the led as i thought on a fl car the hazard switch flashed when locked.
Its wired up though i know this as i plugged it back in when i changed the mirrors
The only reason I noticed it not working was after switcing cluster for maxidot. Id been driving swmbo's yeti and seen that flashing as soon as it was locked and couldn't remember when the last time I saw it flash on the o2. I think I'm going to have to investigate the sensors are working as suggested by Mike earlier.
I know my interior sensors work as the kids set it off when they were left inside the car while i nipped in the shop.
I'm going to try something similar with the dog when I get back from europe as brought swmbos yeti. I suspect the same as you though, the sensors still work, just not the led. Must check fuse 35 though, just to make sure.
The button to turn of the sensors also works on mine and no faults when scanned either.
Im guessing the fl may be different somehow and thats why the hazard light switch flashes
LED in the door flashes on my 2010 FL, never noticed the hazard switch flashing though.
Same here, door LED flashes as it did on my pre fl Octy
Hmmm, still no wiser. With the dog in the car and alarm active, it goes off. Disable it and it doesn't (of course!) Fuse 35 good, but still no door flashy led anymore. Not a biggie, but damn anoying.
Had a look at the car last night and the hazard switch does indeed flash along with the door LED
Just found a post in the o3 area ref the flashig led, it was apparently a disconneced wire. Going to investigate and see what I can find.
 The Hazard light should only flash when you lock/unlock the vehicle, as the Hazard lights flash to tell you the alarm is on or off, it should not flash all the time, thats why the door led is there.
I am not talking about the hazard lights themselves but the switch in the centre of the dash. It flashes in time with the door led
My hazard switch only flashes when i lock/unlock my car, not all the time unless it's another way of showing a fault in the system.
42 minutes ago, mikeholroyd said:
As said above, on the FL octy and superb, the red led in the hazard light switch flashes all the time when the car is locked and the alarm is active, but flashes so dimly you'll only notice it when it's pitch black. It was months before I even realised mine did, came straight on here when I did notice it, and found quite a few threads which all said the same thing  that this was normal.
Mike
Mike, do you have a flashy door indication as well? Mine has, flashed brightly enough to notice during the day, but never noticed the hazard indicator switch illuminating in any way whatsoever. Any idea if the two are linked, electrically, i.e. series/parallel or separately?
Carl.
Not noticed hazards but door indicator flashes a couple of times then stays lit.
1 minute ago, mikeholroyd said:
Yes the door LED is bright, and easily seen in daytime, but the hazard switch is very, very dim. They will be linked to the same function, but probably controlled differently by the BCM - they do not flash exactly in sequence with each other.
Mike
Right, that suggests to me coding. Going to get vcds on the case this weekend and compare a fresh scan to an older one, also check with a scan from swmbos yeti and se if there's any similarities in the long coding.
