fabia vrs alloys?
hi i know its been covered before but just wanted to check will 8x17 et35 offset
fit under ok whats the best tyre size for size rim
cheers chris
spend ya money on tunin instead.
8"? That's wide, that is. Shifty's the man to ask. I think he runs 8" x 18" jobbies.
cheers chris
This will give you 17mm less inside clearance and 21mm less outside clearance than the standard Fabia vRS wheels.
They should fit OK and tyres should be 215/40/17 which is around 2.2% larger than std. tyres
