Mot Issue
So as some are aware my Tfsi burns oil and shows this after being idle as set off. I've got used to the oil usage.
Mot is jow due and i worry it will fail on emissons what are the chances of this? Any suggestions to maybe help !?
So car failed on emissions not the smoke as he said looks more like fumes.
So me being idiot forgetting the decat fitted when got he car, if I fit standard one back on do you think this will solve the high CO reading??
A modern petrol engine won't pass an mot without a catalytic converter. I've never heard of it anyway. I would be looking into why the car is burning so much oil. It's top end rebuild needed by the sound of it.
What is the number required to pass the MOT and what value did you get?
About that oil burning. What kind of driver are you - do you drive the car hard or are you a fuel saver? Just heard a story from a guy who had this oil consumption problem (not on Skoda, though). He went to a dealer and he suggested him to drive harder (the car had automatic transmission that used to choose low rpm). He didn't believe much in that but as the alternative was rather expensive engine repair, he decided to have a try. For some time he switched to manual gear change and after ~2k km he managed to have no oil consumption at all.
Edited by Jevpls
spelling mistake
Max 30 it says and I got 51 on both runs.
as for oil consumption it is not massive it's standard amount.
I do have a PCV fitted and am wondering is this part of the cause stopping car from breathing ??
Im a driver I like to go steady but also drive her hard.
