After market stereo headunit, options?
Afternoon.
I am looking to change the headunit on my 08 Octy VRS. It is standard at present. I would like DAB and Bluetooth.
Budget isn't huge. Any recommendations, are the Android ones on eBay any good?
Thanks for your help
Hi, I believe you have posted this in the wrong forum as this is the Fabia mk2 forums. But I can help you with radio upgrades as they are basically the same radios on the VAG range (I might be wrong) I upgraded my Swing radio with a Skoda Amundsen+ DAB / Bluetooth for around £300 and it was plug and play being a Skoda radio and works with the maxi dot too.
I wouldn't recommend Chinese android units... cheap and nasty plus slow boot up time and they just don't do as good of a job as reputable brands plus if it fails you have to go through ebay to solve and its just a pain. If you don't want to go for Skoda you can get a double din radio or adapt the double din space to a single din radio which had DAB and Bluetooth included but it wont communicate with the cars maxi dot.
For my penny worth I got a pure highway 600 DAB+ fitted by Halfords £150. Only new model head units have DAB+
Edited by Kenrw8
Did you manage to wire up a microphone on this?
Yep, the interior light has a cut out for where the OEM microphone goes and I ran the lead down the left A pillar and into the radio, the Mic cost me around a tenner. Its a super easy job compared to after market radios which need ISO harnesses and a bit of wiring to a 12v ignition line to power the device up.
