Amundsen and DAB
Hi,
I have just got my Rapid and had the Amundsen installed rather than the Swing.  The car was prebuilt and this was the spec that it came with so I did not have the car specifically built and therefore did not look into the details of the Amundsen unit beforehand.
I was surprised that when I looked at the Amundsen unit there was no DAB option but I cannot find anywhere in the manual or online that says that the DAB tuner is an option.  When I click on FM the only other option I get is AM.
Can anyone clarify that on the Amundsen unit DAB is an option whereas on the Bolero unit it is included as default.  This is not a major problem but just something I would like cleared up.
Rich.
was this a new car ???
dont think mine says dab just radio and you have the option within the radio screen of dab or fm/am
Edited by malcster
Yes it was a new car.  The physical button on the unit says radio.  When I select that there is a soft button on the bottom left that says FM, when I select that I get a choice of FM or AM, no DAB.  On the Fabia i get the choice of DAB as well.
Rich.
Is it the mib2 shaped radio (like In your fabia )
Or is it the earlier shape
Pic would clear it up also if it's the earlier shape in system information you can get a part number for the unit that should tell straight away
Hmm, I thought it was the same shape as the one in the Fabia, now not so sure.  Will go have a look and get a picture.  Thanks for your help.
Right here is a picture and the information about the unit.
Device part number: 5Q0035864B
Hardware: H30
Software: 0359
Navigation database:
5L0051236P
0730
ECE1 2017
SHIELD: SHIELD 2016-03 (build 020)
Media Codec:
3141.0.0.1
DAB is an option on that unit.
Thank you, at least I now know now that I am not missing anything.  Strange how some units have it in and some do not and yet they all seem to be called Amundsen with no mention of different version.
At least the FM reception is a massive improvement over my previous unit.
  • 6 months later...
How do you activate DAB?
You don't. If it's fitted then it works. If it isn't fitted then you can't "activate" it.
