Been a While!
HI All,
been a while since i have been here since getting my self a 5 series, my old skoda vrs has been sat for a year and a half waiting for my wife to pass her test, that time is now approaching (after a break in the middle for another baby!)
so having been sat this long, (apart from every month or so being started and run up and down the drive) what should i change and service before an MOT?
my current list is:
OIL + Filter
Break Fluid
but what else?
im going to take off each wheel and make sure the calipers are still moving ok (breaks work but are a bit scrapy... due to lack of use and rusty discs)
any other recommendations?
Daz
Flush the cooling system and put fresh coolant in it.
  • Sponsor
Check that the battery light comes on with ignition. Check the starter solenoid wire for insulation cracking/imminent breakage, near the connector. Check the ABS strip-fuse on the battery fuse-holder for corrosion/cracking.
None of these are things that will have deteriorated during storage, but all are common failure points that you might pre-empt becoming problems by just inspecting.
Inspect all the tyres carefully, with wheels off the car.
Oh, and have a good look at the console bushes if they are by any chance factory originals.
Edited by Wino
cheers guys, will check these things also!
