Wiper washers not working
Hi guys,
Much needed help required,
My front and rear washers are not working. I've checked a few things so far; My pumps ok, fuse 15 is ok. So I am asuming it must be the relay, but the trouble is I dont know where it is located. Iv had a good look under the dash and in lots off different places but just cannot seem to find it, so does anyone know where it is located?
Thanks and any help is much appreciated,
Jack.
  • Sponsor
Don't think there is a relay?
Do you get 12-ish volts at the pump connector when the wash function is triggered by the stalk?
Edited by Wino
Correction
...or do you get a puddle under the car?
Hi,
Will need to check the pump connection,  there is no puddle/leaks under the car.  I'll get back once I've checked the connection.
Thanks a lot for your help :)
