Front Right Low Beam Light Not Working
Hi,
Last weekend my front right low beam light stopped working. I've swapped the ballast and bulb with the left side and the left works and right still does not so its not the ballast/bulb.
I've looked at the fusses under the hood. The left light seems to have a huge fuse and the right a small fuse (going by the car manual). Both look ok. Removing the right and replacing it does nothing. Removing the left turns the light off so its the correct fuse.
The dash comes up with a warning to check the light so the system knows there is an issue.
Where do I go from here?
I've borrowed a VCDS, maybe that will show something tonight...
  • Sponsor
Check fuse 11 in the dashboard fuse holder.
Thanks Wino, checked all fuses and all are ok.
Just to add to this, I found the rubber cover missing from the back of the light. looks like some moisture has got in. Not good....
The VCDS gives the errors below. The "00907 - Intervention load Management" might be due to running the lights and VCDS for ages without starting the car.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 AB    HW: 1K0 937 087 AB
   Component: BCM PQ35  H+  110 0651
   Revision: 00110 AC
   Coding: 48010AB8E85BF1C040080080310089E4417000AE736D85605C8140000040
   Shop #: WSC 33361 790 00999
   VCID: 71AA1AFEA89E01C916-8024
   Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 22021  26  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 240212 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
2 Faults Found:
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 221
                    Mileage: 96414 km
                    Time Indication: 0
                    Date: 2017.03.10
                    Time: 21:54:13
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.85 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 221
                    Mileage: 96414 km
                    Time Indication: 0
                    Date: 2017.03.10
                    Time: 21:54:13
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.85 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1377095
   VCID: 3424D3EA570C74E13D-8060
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000021
1 Fault Found:
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 221
                    Mileage: 96414 km
                    Time Indication: 0
                    Date: 2017.03.10
                    Time: 21:54:12
             Freeze Frame:
                    Voltage: 11.79 V
                    Speed: 0.0 km/h
                        ABS 1
On 11/03/2017 at 05:59, silver1011 said:
See here...
http://wiki.ross-tech.com/wiki/index.php/00907
And here...
http://wiki.ross-tech.com/wiki/index.php/00979
Wiring issue, likely down to corrosion?
Thanks for these. The '907 Intervention load Management ' has gone away after I started the car and drove it. Must have been due to leaving the lights etc on too long.
The 979 error is still there.
I've looked at all the connectors I can see and they don't look corroded. Any ideas on how to check the wiring using multimeter?
  • 1 year later...
hi. how did you fix the issue ? i have the ssme proble on my left headlamp. everything works except for the low beam(dipped beam). the bulb is fine, but i haven’t checked the ballast because i cant really reach behind the headlamp without taking the bumper out.
Hi Pete, I ended up buying a ballast off ebay for about AU$35. Has worked fine since then. Note: it was a pain getting the light out (have to take off quiet a few bits), but better then $$$ for mechanic. If it dies I'll just get another one...
