DRLs - On or Off
26 minutes ago, TLV said:
I'm considering changing that with VCDS.
Not sure VCDS can do that... it certainly couldn’t when i had my MKII
  • Replies 63
  • Views 5.9k
  • of course it will reduce the life of the bulb if they are on! They are a good idea to have on imho as they help increase daytime visibility. The bulbs cost hardly anything so why not just ke
  • just move to Manchester.
  • Auric Goldfinger
    Auric Goldfinger
    You'll be wanting a dimmer switch for the Sun next..............
Then I must be remembering incorrectly. As I recall, it was possible by changing the locale in the lighting module to one where rear lights are mandatory by law. My memory has never been all that great, however.
On the older cars you could select the Scandinavian setting, this would put the front (dipped beam) DRLs and rear sidelights on all the time, this is no longer on option on the MKII.
Just now, mikeholroyd said:
VCDS can easily do rear DRLs on the Superb 3 and Octy 3.
Coding is in andyvee's brilliant thread about tried and tested O3 modification.
Mike
True (I did mine) but this is for a MKII. :thumbup:
That will be why I didn’t do it that way then as my MKII (2010 estate) had separate DRLs in the fog light housings, which I wanted to keep lit and not use the xenons.
I turned them off because it looks like I've got my fog lights on all the time.
So is it possible to have the front drls on all the time on the superb II? I'm assuming it would require vcds to do it though?
DRLs are too bright to be used at night when they would cause dazzle.
Source:https://www.theaa.com/driving-advice/safety/daytime-running-lights
Edited by TLV
Ok understandable but my Mondeo had drls that stayed on all the time?
OEM DLR's should dim when dipped beams are on.
8 minutes ago, mikeholroyd said:
No, OEM DRL's should dim when the side lights are switched on.
Mike
That I did not know. Never really paid much attention I suppose.
I assume they would get overridden altogether when dipped beam's are switched on, no?
And brightness would definitely depend on which bulbs are used. The modern LED type could well be too bright, or too distracting at least.
Mine are the old style, with halogen (I think) bulbs.
No!.
Drl's dimmed so no longer operating as being Daytime / Daylight Running lights can stay on with sidelights and sidelights / headlights so not overridden with many vehicles.
Mine do on the A4...........Just checked........overridden altogether by the sidelights........I thought they were.......
