Towbar Prep
How can you tell if a car has had towbar prep?
I know its probably on the code sticker, but need some guidance on which code it is.
On my Scout the code for towbar prep is 1D7. You might find this website helpful. http://vag-codes.info/
Hi, That's great many thanks.
The firm that fitted my towbar fitted and coded a dedicated wiring loom at ~£120 in addition to the towbar hardware. Not cheap but turns off the rear parking sensors and turns on the towing stability when a trailer etc.  is plugged in. I think that loom may replace the wiring preparation you mention .
