Wonky wipers
Hi everybody,
Jumped in my Vrs this morning, went to clean the front windscreen with the wipers nothing happened apart from the rear wiper working!, aint got no jets working either, anybody experienced this before?
Is your bonnet fully shut? Also check the fuse for the wipers :D
Chris
Fuse, you have blown it due to frozen washer jets.
By any chance was the windscreen frozen and the wipers were just used? Pretty much sure it's exactly as Chris' post suggests.
No spare fuses in the fuse box thing so may be worth picking up a set from your petrol station or Halfrauds or something.
The frozen pipes make sense, but i already checked out the fuse's and no sign of failure there, i rang my local skoda dealers up and they were a bit stand-offish about it being covered under the warranty, so i think that i have to try and suss this one out myself! so much for customer care!!!
If you're sure you've checked the right fuse(s) and it's OK, I can't see what reason at all they'd be suggesting it's NOT covered by the warranty...
