Sat Nav
In an SEL Octavia 2015 is it possible to see on the Sat Nav all the turns and roundabouts before you start as you can on a Garmin, if so how? All i get is the next three turns or junctions.
If it is on the Amundsen, then once the route has calculated, press the LH soft key at the bottom of the screen, select route information, there are a couple of options to explore.
