knocking noise again
Hi all I've still got a knocking noise from my front suspension drivers side, I had the drop links changed the other day and noise went but now it has returned.It did start from the passengers side but when the tyres got changed it jumped to the drivers side.my cars an octavia vrs 2012 only done 35000 miles feel like selling it, it's doing my head in..
Thanks for the reply Mike which do you think I should change first.
I've just had a thought the knocking noise was coming from the passengers side  but when I had my tyres changed the noise moved over to the drivers side is there a possibility the noise is coming from the wheel and they put the passengers wheel on the drivers side.
Possible but seems unlikely. You should be able to see wheel damage with wheel off and inspecting it. You could move front to back but I would be thinking Mikeholroyd suggestions in post 2 are more likely.
Another thing when driving over bumps with the window down  I can here a noise which sounds like air being realised is this normal..
Thanks Mike much appreciated.
First thing I would try is to tighten the front subrfame bolts.
They are stretch bolts and stretch loose..
And its free..
I would jack it up, support on axle stand on jacking point then put a scaffolding pole or similar under the front wheel/tyre in question and move it up and down to simulate suspension movement on road and I bet you can track down where the noise is coming from.
5 minutes ago, mikeholroyd said:
I bet you'd not. When my suspension was knocking, three separate outlets including a main dealer could not find any movement in any component, though all three agreed the knock was there. It was only when the struts were removed that you could tell the top bearings and mounts were shot.
Mike
Got to be worth a shot, free after all.
11 hours ago, mikeholroyd said:
Never once heard of subframe bolts working loose. Octavia is well known for wear in suspension components as above in this thread. You'll end up replacing something for sure, and the first thing to check would be the cheapest to replace without stripping the struts out, namely bottom wishbone bushes and drop links.
Mike
Whats cheeper than putting a bar on a bolt???
Just because you have never heard of something doesn't say it doesn't happen.
Jettas ,mk5 golfs,B6 Passats etc all suffer from subframe bolts stretching..........
Octavias share the same suspension clip.
Quick google search
Edited by usedabused
Got a 62 plate Vrs.Mine knocks passenger side but only slow speed.Three different mates and a garage have said that in thir opinion its the way the tyre is wearing.I am used to it(after nearly a year)so dont let it bother me.
