Keys and VCDS Coding
Morning folks,
Having just retrofitted Maxidot, and checked with newly coded key (cheers Eddie-Nl), I'm just coding the display. I have a couple of general issues which I am sorting through, however, I have noticed that both of my keys provide different fuctionality within Maxidot. Would I be right in thinking that any adaptions made with one key, must be made again with the second key, or, do I need to code the second key via vcds, if at all possible?
The second thing is, is there anyone with a VCDS scan of a FL O2  that they can post so that I can check that I'm doing this right and have the right box's ticked/unticked. I realise that there will be numerous combinations of equipment fitted / and personal adaptions, however it would be useful to be able to check that I've not missed something.
All help, as always, greatfully received. Thank you.
After further investigation, my MFSW right hand side buttons do nothing except:- the scroll button accepts changes to the display on click only. Changing the display requires a 2 second push on the wiiper stalk.
Having looked on VCDS, I have 2 options on steering wheels!! There is then a pop up box giving coding info for variations (see attached photo). How to code the correct options so that functionality is held by the MFSW as opposed to the stalk?
Further investigation shows I have the wrong coding!! Currently 0000130, nearly all wrong! Should be 0005104 to match my spec. Will recode tomorrow and see what happens. Still havn't figured out the key issue.
Well that didn't go according to plan! Now have:-
00895 - Cruise Control Switch (E45)
            014 - Defective - Intermittent
00002 - Transmission Control Unit
            004 - No Signal/Communication
00380 - Special Vehicle Control Module (J608)
01426 - Controls in Steering Wheel (E221)
00895 -  That could be because I don't yet have it fitted!
00002 - according to Ross Tech Wiki, with the symptoms that I have, it could be that the key that did NOT go with the new instrument for coding might not be matched to the cluster. Did notice that I don't have a flashing immobiliser light on drivers door when using that key.
00380 - that could be my sausage fingers when coding!
01426 - Slightly more concerning as the right hand buttons do naff all.
The wiper stalk, buttons on the end and underneath do all the functions on the max display, apart from, I can reset the trip distance to zero by pressng the scroll button!
Further investigations on RTW indicate possible loss of coding for the unmatched key, however, I can't access module 46 - central convenience, it shows no errors.
The search for truth and understanding continues.
Edited by Canders
update
The search for understanding is not going well!!
Anyone know why, in the scan below, module 46 is scanned in the auto scan, but does not show up in the file afterwards and is inacessible for coding?
Please ignore the faults, I know what's going on there (sausage fingers!!)
Cheers.
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 TB    HW: 03G 906 021 AN
   Component: R4 1,9l EDC  000SG  2047
   Revision: --H11---    Serial number:
   Coding: 0000071
   Shop #: WSC 73430 790 00999
   VCID: 72EA555D6D6323D1EF-8026
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0104
   Revision: 00H35001
   Coding: 0017665
   VCID: 7BF478793A296299BC-802E
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 M    HW: 3T0 820 047 M
   Component: Climatic      150 0303
   Revision: 00006001
   Coding: 0000000002
   ASAM Dataset: EV_Climatic A01005
   ROD: EV_ClimaBasis_SK35.rod
   VCID: 3978A271B8959089EE-806C
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
   Component: BCM PQ35  B   103 0573
   Revision: 00103 AF
   Coding: 48180AB8B05BB1C04008008011000024430000AE524D81605C4440000000
   VCID: 2D50862174DD3C2972-8078
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 29100  22  0601
   Coding: 00DFB7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
1 Fault Found:
02395 - Parking Light Front Right (M3)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 157
                    Mileage: 166048 km
                    Time Indication: 0
                    Date: 2017.04.13
                    Time: 07:41:50
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2GX9E.
   Coding: 0020788
   VCID: 3D70B66164BDACA9C2-8068
   Subsystem 1 - Serial number: 6332MSME4A4027075
   Subsystem 2 - Serial number: 6342MSME4C22293DJ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           056 0111
   Coding: 0021104
   Shop #: WSC 131071 999 209715
   VCID: 76E2694D010B3FF1C3-8022
4 Faults Found:
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 943 S    HW: 1Z0 920 943 S
   Component: KOMBI         H06 0608
   Serial number: 00000000000000
   Coding: 710900
   Shop #: WSC 00152 210 91233
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
   VCID: 4998D2B1E87500097E-801C
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0231
   Revision:   H16       Serial number: 4320K09B02028C
   Coding: E9807F06000202002303
   VCID: 69D8323140B5E0095E-803C
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0608
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADA4D3D8DB3EB1157-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2114
   Coding: 0000756
   VCID: 489ED7B53B7FF90161-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 68     3001
   Revision: 00H17000
   VCID: 31689A51A8E558C956-8064
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 479CD4893661F67968-8012
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        008 0053
   Revision: 0A001001    Serial number: SKZ1Z3I8176322
   Coding: 000004000001
   VCID: 3560AE419C8D74E90A-8060
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 326A955DADE363D12F-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3364905952F96AD924-8066
End-------------------------(Elapsed Time: 01:45)--------------------------
This is the answer I got from Langers2k when I asked the question recently.
"On the pre-FL, the CECM and CCM are separate modules (address 09 and 46).
On the FL, the BCM replaces both with a single module (address 09) but also creates a 'virtual module' at address 46. This is completely normal and you aren't suppose to access address 46"
Thank you very much. That answers several issues. How I missed your original post, I don't know. Just need to sort out the faults and figure out why I can't use the right hand buttons on the MFSW now.
Thanks again.
Update, both keys work correctly, and with Eddie-Nl's help, the rh buttons on mfsw now work. This was achieved by changing the coding, locking the car door, waiting until the instrument cluster goes blank, then unlocking. The lock/unlock step is required to allow the coding to set. Onwards and upwards.
You should code the steering controller 0000532 if you intend to fit cruise
or
0000502 if you don't
You should also code the BCM (09)
Coding > Long Coding > scroll through and look for MF trip computer by BAP. can't remember the exact name.
Tick that and you should have convenience and lights and vision
There is also an individual key option in there too
Edited by Eddie-NL
You would also need to enable cruise in the Engine if you want to add cruise
Coding II = 11463
Edited by Eddie-NL
Was going down the route of cc but came across a thread on one of the golf forums which indicated that the bcu i currently have fitted is incorrect for cc/acc fitting. Lost thread of where I was, but now easter is over, will get back amongst it.
