Birth to 50,000miles Citigo Servicing
So we are getting close to 50,000miles and i had alooky at the cost of running our citigo as now just over 3 years old.
I had look back at the costs on servicing:
10,000miles - Service - £FOC came with Citigo
20,000miles - Service - £FOC came with Citigo
30,000miles - Service - £149.00
40,000miles - Service -  £277.62
48,000miles - MOT - £39.00
50,000miles - Service (£149), Brake Fluid & Brake Discs & Pads (£240) - £389.00
50,000miles - Tyres Fitted (fronts) - £163.00
So in reality (not including fuel and insurance) the maintenance per mile for the Citigo has been 0.02p per mile.
Happy with that! :)
It hasn't.
It's 100 times more expensive than that.
Still good value though.
Ho can it be 100 times more expensive? 50,000miles in maintenance has cost £1,017.62. Divide that by the 50,000miles then the maintenance cost per mile is £0.02p
£1,017.62 divided by the 50,000miles is £0.02 or 2p per mile
Your initial 0.02p per mile is £0.0002 per mile.
'spec savers' for someone, or was the OP edited because it says 0.02p per mile.  (or 2 pence per mile)
Did you manage 1 pence per mile on petrol over the 50,000 miles?
  • Sponsor
0.02p per mile is 2 pence per 100 miles.
£0.02 per mile, 2p per mile is what the OP meant.
No wonder young and old and others get confused.
100 pence in £1
so £1.00
£1 & 2 pence,
£1.02
20 pence,
£0.20
2 pence,
£0.02
12 pence,
£0.12
Pity the £ was never changed to the euro when imperial gallons
& the UK could also have gone totally metric.
Edited by Awayoffski
  • Sponsor
Back from specsavers already, well done.
50,000mile service all completed without any issues. £400 spent on the Citigo and after 3 years it felt like a new car again. I was rather surprised how much new rubber improved the driving experience.
Why not rotate tyres? From front to rear and from rear to front? For example every 10000 miles. This way tyres wears more evenly.
Just thought I might add to this thread as my daughter has just bought a 3yr 9m old Citigo with just a couple of hundred miles short of 50,000 on it. One lady owner from new and it's the 75hp elegance spec model.
First registration  26/07/2013
Serviced 10,302  12/03/2014 £129 - Skoda main dealer - oil, filter, screen wash and sump plug & service charge £66
Serviced 20,362  05/12/2014 £176 - Independent - oil, filter, air filter, pollen filter, engine flush & 2 hours labour at £38 p/h
Serviced 35,090  15/01/2016 £274 - Independent - oil, filter, air filter, engine flush, 2 Conti tyres (£93) & 2 hours labour at £38.50 p/h
MOT       41,994  15/07/2016 £  54 - Independent - no advisories
New key 46,887  30/11/2016 £130 - Independent - supplied, cut and reprogrammed spare key
Serviced 48,690  23/01/2017 £190 - Independent - oil, filter, cabin filter, engine flush & rear brake strip & clean & 2 hrs labour at £39.50 p/h
Plugs & coils       25/01/2017 £  67 - Independent - Spark plugs and coil insulators replaced
Serviced 49,751 20/03/2017 £649 - Skoda main dealer - oil, filter, pollen filter, screen wash, wiper blades, brake discs and pads, 2 x Kuhmo tyres (£67), spark plugs, heat shield, bulb, and sump plug
Seems daft to have just serviced it again when it had only done 1,000 miles since last one. The only other thing is that the reprogrammed spare key doesn't work. The car is a little cracker and I really like it :)
Edited by Sheriff
How much were the spark plugs, out of interest? I just had a major service and MOT (at 40k) at an independent, £510, mostly the same as above but without tyres or brake discs (but brake pads replaced), doesn't seem like I saved much compared to a main dealer.
Car feels great now though, particularly with the Avon ZV7s I had fitted recently as well. For such a small light car I've been amazed at how much difference tyres actually make, the Firestones I had fitted previously were pretty poor (wheelspin in damp conditions, tendancy to tramline) but so far the Avons have been brilliant.
Our 40,000 Service at Skoda Dealer was £277.62 included :- Mobil Oil, Oil filter, Washer, Cleaner, Pollen filter, Air filter, Spark plugs & wiper blade rear
Edited by Citigouk
Hi, the dealer parts prices were as follows (20/03/2017)
Spark plug £5.01
Oil filter £6.33
Brake disc £37.89
Brake pads £32.66 (pair)
Pollen filter £10.01
Brake fluid £8.66 (litre)
Screenwash £4.41
Sump plug £2.62
Engine oil £8.19 (litre)
